Cube plots can be used to show two to eight factors - with or without a response measure - for two-level factorial or Plackett-Burman designs. Viewing the factors without the response allows you to see what a design "looks like." If there are only two factors, Minitab displays a square plot. You can draw a cube plot for either data means or for fitted means:
Cube Plot - No Response |
Cube Plot - With Response |
Although you can use these plots to compare effects, be sure to evaluate significance by looking at the effects in the analysis of variance table. |
