Example of C chart with customized control limits
Suppose you work for a linen manufacturer. Each 100 square yards of fabric can contain a certain number of blemishes before it is rejected. For quality purposes, you want to track the number of blemishes per 100 square yards over a period of several days, to see if your process is behaving predictably. You want the control chart to show control limits at 1, 2, and 3 standard deviations above and below the center line.
1    Open the worksheet EXH_QC.MTW.
2    Choose Stat > Control Charts > Attributes Charts > C.
3    In Variables, enter Blemish.
4    Click C Chart Options, then click the Limits tab.
5    Under Display additional sigma limits at, enter 1 2 in These multiples of the standard deviation.
6    Under Place bounds on control limits, check Lower standard deviation limit bound and enter 0.
7    Click OK in each dialog box.
Graph window output
Interpreting the results
Because the points fall in a random pattern, within the bounds of the 3s control limits, you conclude the process is behaving predictably and is in control.
