查看: 124|回复: 0
抽油泵UL认证UL79A检测报告专业实验室出具
帖子
发表于 2021-1-7 16:33:58 | 显示全部楼层 |阅读模式
认证检测
分类: 电子电气&数码家电(IT)
STANDARD FOR SAFETY
Power-Operated Pumps for Gasoline and Gasoline/Ethanol Blends with Nominal Ethanol
Concentrations up to 85 Percent (E0一E85)
UL Standard for Safety for Power-Operated Pumpsfor Gasoline and Gasoline/Ethanol Blends with Nominal Ethanol Concentrations up to 85 Percent (E0- E85), UL 79A
This revision ANSI/UL 79A revises the MoistAmmonia-Air Stress Cracking Test.
The revised requirements are substantially inaccordance with Proposal(s) on this subject dated March 18,2016
All rights reserved. No part of thispublication may be reproduced, stored in a retrieval system, or transmitted in any form by anymeans, electronic, mechanical photocopying, recording, or otherwise without prior permission of UL.
UL provides this Standard "as is"without warranty of any kind, either expressed or implied, including but not limited to, the impliedwarranties of merchantability or fitness for any purpose. In no event will ULbe liable for any special, incidental, consequential, indirect or similardamages。
安全标准
汽油和汽油动力驱动泵
汽油/乙醇与标称乙醇的混合物
浓度高达85%(E0一E85)
UL汽油和汽油/乙醇混合物动力驱动泵的安全标准
标称乙醇浓度高达85%(E0-E85),UL 79A
此修订版ANSI / UL 79A修订了湿氨气应力开裂测试
修订后的要求基本上符合2016年3月18日关于此主题的提案版权所有。本出版物的任何内容均不得复制,存储在检索系统中,或通过电子,机械影印,记录或其他方式以任何形式传输未经UL事先许可。
UL按“原样”提供此标准,不提供任何形式的明示或暗示担保,包括但不限于:
不限于对适销性或适用于任何目的的默示保证。
对于任何特殊的,偶然的,后果性的,间接的或类似的损害,UL概不负责
13132337007
简繁转换|Minitab 帮助|图形|DOE|统计|手机版|联系本站|品质协会(www.PinZhi.org)
GMT+8, 2021-1-24 05:17 , Processed in 0.033269 second(s), 6 queries , Gzip On, Redis On.
Powered by Discuz! X3.4
品质协会 品质人,让一切变得更美好.
