查看: 1651|回复: 2
IEC 60749-26:2018 Electrostatic discharge (ESD) sensitivity testing - Human body
发表于 2018-1-20 10:54:21 | 显示全部楼层 |阅读模式
IEC 60749-26:2018 Semiconductor devices - Mechanical and climatic test methods - Part 26: Electrostatic discharge (ESD) sensitivity testing - Human body model (HBM)
IEC 60749-26:2018 establishes the procedure for testing, evaluating, and classifying components and microcircuits according to their susceptibility (sensitivity) to damage or degradation by exposure to a defined human body model (HBM) electrostatic discharge (ESD).
The purpose of this document is to establish a test method that will replicate HBM failures and provide reliable, repeatable HBM ESD test results from tester to tester, regardless of component type. Repeatable data will allow accurate classifications and comparISOns of HBM ESD sensitivity levels.
ESD testing of semiconductor devices is selected from this test method, the machine model (MM) test method (see IEC 60749-27) or other ESD test methods in the IEC 60749 series. Unless otherwise specified, this test method is the one selected.
This fourth edition cancels and replaces the third edition published in 2013. This edition constitutes a technical revision. This standard is based upon ANSI/ESDA/JEDEC JS-001-2014. It is used with permission of the copyright holders, ESD Association and JEDEC Solid state Technology Association.
a)   a new subclause relating to HBM stressing with a low parasitic simulator is added, together with a test to determine if an HBM simulator is a low parasitic simulator;
b)   a new subclause is added for cloned non-supply pins and a new annex is added for testing cloned non-supply pins.
发表于 2022-5-3 11:42:55 | 显示全部楼层
发表于 2022-11-10 13:15:55 | 显示全部楼层
标准呢?
《品质协会规则》|品质币|品质B2B|手机版|加入协会|联系我们|品质协会(www.PinZhi.org) |网站地图
GMT+8, 2024-4-25 06:46 , Processed in 0.037370 second(s), 5 queries , Gzip On, Redis On.
