Stat > DOE > Factorial > Create Factorial Design > choose General full factorial design > Designs > Factors
Allows you to name or rename the factors and assign values for factor levels. If your factors could be continuous, use numeric levels; if your factors are categorical, use text levels. Continuous variables can take on any value on the measurement scale being used (for example, length of reaction time). In contrast, categorical variables can only assume a limited number of possible values (for example, type of catalyst).
Use the arrow keys to navigate within the table, moving across rows or down columns.
Factor: Shows the number of factors you have chosen for your design. This column does not take any input.
Name: Enter text to change the name of the factors. By default, Minitab names the factors alphabetically, skipping the letter I.
Type: Choose to specify whether the levels of the factors are numeric or text.
Levels: Shows the number of levels for each factor. This column does not take any input.
Level Values: Enter numeric or text values for each level of the factor. You can have up to 100 levels for each factor. By default, Minitab sets the level values in numerical order 1, 2, 3, ... .
