Stat > DOE > Factorial > Create Factorial Design > Results
You can control the output displayed in the Session window.
Printed Results
None: Choose to suppress display of the results.
Summary table: Choose to display a summary of the design. The table includes the number of factors, runs, blocks, replicates, center points, and the resolution, the fraction and the design generators.
Summary table, alias table: Choose to display a summary of the design and the alias structure.
Summary table, alias table, design table: Choose to display a summary of the design, the alias structure, and a table with the factors and their settings at each run.
Summary table, alias table, design table, defining relation: Choose to display a summary of the design, the alias structure, a table with the factors and their levels at each run, and the defining relation.
Contents of Alias Table
Default interactions: Choose to display all interactions for designs with 2 to 6 factors, up to three-way interactions for 7 to 10 factors, and up to two-way interactions for 11 to 15 factors.
Interactions up through order: Specify the highest order interaction to print in the alias table. Specifying a high order interaction with a large number of factors could take a very long time to compute.
