Example of specifying generators
Suppose you want to add two factors to a base design with three factors and eight runs.
1    Choose Stat > DOE > Factorial > Create Factorial Design.
2    Choose 2-level factorial (specify generators).
3    From Number of factors, choose 3.
4    Click Designs.
5    In the Designs box at the top, highlight the row for a full factorial. This design will serve as the base design.
6    Click Generators. In Add factors to the base design by listing their generators, enter D = AB     E = AC. Click OK in each dialog box.
Session window output
Fractional Factorial Design
Factors:  5   Base Design:         3, 8   Resolution:  III
Runs:     8   Replicates:             1   Fraction:    1/4
Blocks:   1   Center pts (total):     0
* NOTE * Some main effects are confounded with two-way interactions.
Design Generators: D = AB, E = AC
Alias Structure (up to order 3)
I + ABD + ACE
A + BD + CE
B + AD + CDE
C + AE + BDE
D + AB + BCE
E + AC + BCD
BC + DE + ABE + ACD
BE + CD + ABC + ADE
Interpreting the results
The base design has three factors labeled A, B, and C. Then Minitab adds factors D and E. Because of the generators selected, D is confounded with the AB interaction and E is confounded with the AC interaction. This gives a 2(5-2) or resolution III design. Look at the alias structure to see how the other effects are confounded.
