These are the designs given in [7], up through n = 48, where n is the number of runs. In all cases except n = 28, the design can be specified by giving just the first column of the design matrix. In the table below, we give this first column (written as a row to save space). This column is permuted cyclically to get an (n - 1) x (n - 1) matrix. Then a last row of all minus signs is added. For n = 28, we start with the first 9 rows. These are then divided into 3 blocks of 9 columns each. Then the 3 blocks are permuted (rowwise) cyclically and a last column of all minus signs is added to get the full design.
Each design can have up to k = (n - 1) factors. If you specify a k that is less than (n - 1), just the first k columns are used.
12 Runs
20 Runs
24 Runs
28 Runs
32 Runs
36 Runs
40 Runs (note, derived by duplicating the 20 run design)
44 Runs
48 Runs
