1 Choose Stat > DOE > Factorial > Create Factorial Design.
2 Choose General full factorial design.
3 From Number of factors, choose a number from 2 to 15.
4 Click Designs.
5 Click in Number of Levels in the row for Factor A and enter a number from 2 to 100. Use the arrow key to move down the column and specify the number of levels for each factor.
6 If you like, use any of the options in the Design subdialog box.
7 Click OK. This selects the design and brings you back to the main dialog box.
8 If you like, click Options or Factors and use any of the dialog box options , then click OK to create your design.
