Stat > DOE > Factorial > Define Custom Factorial Design > choose 2-level factorial > Designs
Allows you to specify which columns contain the standard order, run order, center point indicators, and blocks.
Standard Order Column
Order of the data: Choose if the standard order is the same as the order of the data in the worksheet.
Specify by column: Choose if the standard order of the data is stored in a separate column, then enter the column.
Run Order Column
Order of the data: Choose if the run order is the same as the order of the data in the worksheet.
Specify by column: Choose if the run order of the data is stored in a separate column, then enter the column.
Center Points
No center points: Choose if your design does not contain center points.
Specify by column: Choose if your design contains center points, then enter the column containing the center point identifiers.
Blocks
No blocks: Choose if your design is not blocked.
Specify by column: Choose if your design is blocked, then enter the column containing the blocks.
