Stat > DOE > Modify Design > Replicate design
You can add up to ten replicates of your design. When you replicate a design, you duplicate the complete set of runs from the initial design. The runs that would be added to a two factor full factorial design are as follows:
Initial design |
One replicate added |
Two replicates added |
A B - - + + + - - + |
A B - - + + + - - + - - + + + - - + |
A B - - + + + - - + - - + + + - - + - - + + + - - + |
True replication provides an estimate of the error or noise in your process and may allow for more precise estimates of effects.
Number of replicates to add: Choose a number up to ten.
