1 Choose Stat > DOE > Modify Design.
2 Choose Add axial points and click Specify.
3 Do one of the following:
4 If you want to add center points to the axial block, enter a number in Add the following number of center points (in the axial block). Click OK.
If you a building up a factorial design into a central composite design and would like to consider the properties of orthogonal blocking and rotatability, use the table in Summary of central composite designs for guidance on choosing a and the number of center points to add. This option is not available for split-plot designs or designs with text factors. |
