Defining Contours
For each response, you need to define a low and a high contour. These contours should be chosen depending on your goal for the responses. Here are some examples:
·    If your goal is to minimize (smaller is better) the response, you may want to set the Low value at the point of diminishing returns, that is, although you want to minimize the response, going below a certain value makes little or no difference. If there is no point of diminishing returns, use a very small number, one that is probably not achievable. Use your maximum acceptable value in High.
·    If your goal is to target the response, you probably have upper and lower specification limits for the response. Because the graph displays the mean values for the response at the corresponding factor settings, you should set your low and high values well within your specification limits to ensure that individual observations fall with the specification limits. If you do not have specification limits, you may want to use lower and upper points of diminishing returns.
·    If your goal is to maximize (larger is better) the response, again, you may want to set the High value at the point of diminishing returns, although now you need a value on the upper end instead of the lower end of the range. Use your minimum acceptable value in Low.
In all of these cases, the goal is to have the response fall between these two values.
