To set the holding level for variables not in the plot
for a factorial design
main topic see also
1 In the Overlaid
Contour Plot dialog box, click Settings.
2 Do one of the following to set
the holding value for extra variables or covariates:
· To
use the preset values for variables, covariates, or process variables,
choose High settings,
Middle settings,
or Low settings.
When you use a preset value, all
variables not in the plot will be held at their high, middle (calculated
median), or low settings.
· To
specify the value at which to hold the variable, covariate, or process
variable, enter a number in Setting for each of the design variables
you want control. This option allows you to set a different holding value
for each variable.
3 Click OK.
