Stat > DOE > Mixture > Analyze Mixture Design > Graphs
Draw five different residual plots for regular, standardized, or deleted residuals. You do not have to store the residuals and fits in order to produce these plots.
Residuals for Plots You can specify the type of residual to display on the residual plots.
Regular: Choose to plot the regular or raw residuals.
Standardized: Choose to plot the standardized residuals.
Deleted: Choose to plot the Studentized deleted residuals.
Residual Plots
Histogram: Check to display a histogram of the residuals.
Normal plot: Check to display a normal probability plot of the residuals.
Residuals versus order: Check to plot the residuals versus the order of the data in the run order column. The row number for each data point is shown on the x-axis-for example, 1 2 3 4... n.
Residuals versus variables: Check to display residuals versus selected variables, then enter one or more columns. Minitab displays a separate graph for each column.
