Analyze Mixture Design - Storage
Stat > DOE > Mixture > Analyze Mixture Design > Storage
·    store the fits, and regular, standardized, and deleted residuals separately for each response - see Choosing a residual type
·    store the coefficients for the model, the design matrix, and model terms separately for each response. The design matrix multiplied by the coefficients will yield the fitted values. Since Analyze Mixture Design does not allow a constant in the model, the design matrix does not contain a column of ones.
·    store the leverages, Cook's distances, and DFITS to identify outliers
Fits and Residuals
Fits: Check to store the fitted values. One column is stored for each response variable.
Residuals: Check to store the residuals. One column is stored for each response variable.
Standardized residuals: Check to store the standardized residuals.
Deleted residuals: Check to store Studentized residuals.
Model Information
Coefficients: Check to store the coefficients. One column is stored for each response variable. These are the same coefficients as are printed in the output. If some terms are removed because the data cannot support them, the removed terms do not appear on the output.
Design matrix: Check to store the design matrix. When terms are removed because the data cannot support them, the design matrix does not contain the removed terms. The columns of the stored matrix match the coefficients that are printed and/or stored.
Model terms: Check to store the terms that were included in the fitted model.
Other
Hi [leverage]: Check to store leverages.
Cook's distance: Check to store Cook's distance.
DFITS: Check to store DFITS.
