This example fits a model for the design created in Example of simplex centroid design. Recall that you are trying to determine how the proportions of the components in an herbal blend household deodorizer affect the acceptance of the product based on scent. The three components are neroli oil, rose oil, and tangerine oil. Based on the design points, you mixed ten blends. The response measure (Acceptance) is the mean of five acceptance scores for each of the blends.
1 Open the worksheet DEODORIZ.MTW.
2 Choose Stat > DOE > Mixture > Analyze Mixture Design.
3 In Responses, enter Acceptance. Click OK.
Session window output
Regression for Mixtures: Acceptance versus Neroli, Rose, Tangerine
Estimated Regression Coefficients for Acceptance (component proportions)
Term Coef SE Coef T P VIF Neroli 5.856 0.4728 * * 1.964 Rose 7.141 0.4728 * * 1.964 Tangerine 7.448 0.4728 * * 1.964 Neroli*Rose 1.795 2.1791 0.82 0.456 1.982 Neroli*Tangerine 5.090 2.1791 2.34 0.080 1.982 Rose*Tangerine -1.941 2.1791 -0.89 0.423 1.982
S = 0.490234 PRESS = 11.4399 R-Sq = 73.84% R-Sq(pred) = 0.00% R-Sq(adj) = 41.14%
Analysis of Variance for Acceptance (component proportions)
Source DF Seq SS Adj SS Adj MS F P Regression 5 2.71329 2.71329 0.54266 2.26 0.225 Linear 2 1.04563 1.56873 0.78437 3.26 0.144 Quadratic 3 1.66766 1.66766 0.55589 2.31 0.218 Neroli*Rose 1 0.15963 0.16309 0.16309 0.68 0.456 Neroli*Tangerin 1 1.31728 1.31109 1.31109 5.46 0.080 Rose*Tangerin 1 0.19075 0.19075 0.19075 0.79 0.423 Residual Error 4 0.96132 0.96132 0.24033 Total 9 3.67461 |
The magnitudes of the coefficients for the three pure mixtures indicate that tangerine oil (7.448) and rose oil (7.141) produce deodorizers with higher acceptance levels than neroli oil (5.856).
Positive coefficients for two-blend mixtures indicate that the two components act synergistically or are complementary. That is, the mean acceptance score for the blend is greater than you would obtain by calculating the simple mean of the two acceptance scores for each pure mixture.
Negative coefficients indicate that the two components are antagonistic towards one another. That is, the mean acceptance score is lower than you would obtain by calculating the simple mean of the two acceptance scores.
The neroli oil by tangerine mixture is the only two-blend mixture that might be judged as significant (t = 2.34; p = 0.08)
For a general discussion of analysis results, see [1].
