To control plotting of contour levels (mixture design)
main topic see also
1 In the Contour/Surface Plots
dialog box, check Contour
plot and click Setup.
2 Click Contours.
3 To change the number of contour
levels, do one of the following:
· Choose
Number
and enter a number from 2 to 11.
· Choose
Values
and enter from 2 to 11 contour level values in the units of your data.
You must enter the values in increasing order.
4 Click OK in each dialog
box.
