1 In the Create Mixture Design dialog box, click Process Vars.
2 Under Low, click in the process variable row to which you would like to assign values and enter any value. Use the arrow key to move to High and enter a value. If you use numeric levels, the value you enter in High must be larger than the value you enter in Low.
3 Repeat step 2 to assign levels for other process variables. Click OK.
More |
To change the process variable levels after you have created the design, use Stat > DOE > Modify Design. |
