Stat > DOE > Mixture > Define Custom Mixture Design > Designs
Allows you to specify which columns contain the blocks, run order, and standard order.
Standard Order Column
Order of the data: Choose if the standard order is the same as the order of the data in the worksheet.
Specify by column: Choose if the standard order of the data is stored in a separate column, then enter the column.
Run Order Column
Order of the data: Choose if the run order is the same as the order of the data in the worksheet.
Specify by column: Choose if the run order of the data is stored in a separate column, then enter the column.
Point Type Column
Unknown: Choose if you do not have a column indicating the point type.
Specify by column: Choose if you have a column indicating the point type, then enter the column.
Blocks
No blocks: Choose if your design is not blocked.
Specify by column: Choose if your design is blocked, then enter the column containing the blocks.
