Stat > DOE > Modify Design > check Modify variables > Specify > Process variables
Allows you to rename process variables and change process variable levels.
Process Variable
Name: Enter text to change the name of the process variables.
Type: Shows whether the variable is numeric or text. This column does not take any input.
Lower: Enter the value of the low level for each process variable.
Upper: Enter the value of the high level for each process variable.
