1 Choose Stat
> DOE > Mixture > Simplex Design Plot.
2 Do one of the following to select
the number of plots to display:
· To
display a single simplex design plot for any three components, choose
Select a triplet
of components for a single plot. Then, choose any three
components that are in your design.
· To
display a layout with four simplex design plots (each plot displays three
components), choose Select
four components for a matrix plot. Then, choose any four
· To
display a simplex design plot for all combinations of components, each
in a separate window, choose Generate plots for all triplets of components.
3 If you like, use any of the
dialog box options, then click OK.
