When changing the proportion of a component in a mixture to determine
its effect on a response, you must make offsetting changes in the other
mixture components because the sum of the proportions must always be one.
The changes in the component whose effect you are evaluating along with
the offsetting changes in the other components can be thought of as a
direction through the experimental region.
There are two commonly used trace directions along which the estimated
responses are calculated: Cox's direction and Piepel's direction.
· When
the design is not constrained and the reference point lies at the centroid
of the unconstrained experimental region, both Cox's directions and Piepel's
directions are the axes of the simplex.
· When
the design is constrained, the default reference mixture point lies at
the centroid of the constrained experimental region that is different
than the centroid of the unconstrained experimental region. In this case,
Cox's direction is defined in the original design space, whereas, Piepel's
direction is defined in the L-pseudocomponent space.
