Stat > DOE > Mixture > Response Trace Plot > Settings
Use to specify hold values for process variables (the default is the low setting) and the amount variable (the default is the average amount).
Hold process variables at
Low setting: Choose to set variables that are not in the plot at their lowest setting.
High setting: Choose to set variables that are not in the plot at their highest setting.
Process Var.: Shows all the process variables in your design. This column does not take any input.
Name: Shows all the names of process variables in your design. This column does not take any input.
Setting: Enter a value to hold each process variable that is not being plotted. Use the up and down arrows to move in the Setting column.
Hold mixture amount at: Choose a total at which to hold the mixture amount.
