Example of evaluating a design
Suppose you want determine how reducing the model changes the optimality for the 20 point experimental design obtained in the Example of selecting a D-optimal response surface design. Remember that a model that is D-optimal for a given model only.
1    Open the worksheet OPTDES3.MTW. (The design and indicator columns have been saved for you.)
2    Choose Stat > DOE > Response Surface > Select Optimal Design.
3    Choose Evaluate design, then enter OptPoint in the box.
4    Click Terms.
5    From Include the following terms, choose Linear.
6    Click OK in each dialog box.
Session window output
Optimal Design: Blocks, A, B, C, D
Evaluation of Specified Response Surface Design
Number of design points in optimal design: 20
Model terms: Block, A, B, C, D
Specified Design
Row number of selected design points: 1, 3, 4, 6, 8, 9, 10, 13, 15, 16, 17, 19, 22, 23, 24,
                                      25, 26, 27, 28, 30
Condition number:                           1.43109
D-optimality (determinant of XTX):         47267840
A-optimality (trace of inv(XTX)):          0.320581
G-optimality (avg leverage/max leverage):  0.871492
V-optimality (average leverage):                0.3
Maximum leverage:                          0.344237
Interpreting the results
The Session window output contains the following four parts:
·    The number of points in the design.
·    The model terms. D-optimal designs depend on the specified model. In this example, the terms include:
Block A B C D
These are the linear model terms that you chose in the Terms subdialog box. Remember, a design that is D-optimal for one model will most likely not be D-optimal for another model.
·    The selected design points. The numbers shown identify the row of the design points in the worksheet.
·    In addition to the design's D-optimality, Minitab displays various optimality measures. You can use this information to evaluate or compare designs. If you compare the optimality of the 20-point design for a full quadratic model from the example of selecting a D-optimal response surface design with this 20-point design for a linear model, you will notice that the D-optimality decreased from 2.73819E+18 to 47267840. Larger D-optimality values indicate a more optimal design.
Calendar with week numbers
US Federal Holidays
Australia Public Holidays
