You work for a parts manufacturer and must attach a pipe vertically
onto a thin square plate. The heat from welding causes the plate to warp.
You want to design an experiment to try to reduce the amount of warping,
but you are restricted to an experiment using only 32 runs. Four variables
- temperature of the plate (50
The full general factorial design for this experiment requires 64 runs. You want to obtain an optimal design that reduces the number of design points to 32.
1 Open the worksheet FACTOPT2.MTW.
2 Choose Stat > DOE > Factorial > Select Optimal Design.
3 In Number of points in optimal design, type 32.
4 Click Terms.
5 From Include terms in the model up through order, choose 2. Click OK in each dialog box.
Session window output
The Session window output contains the following five parts:
A, B, C, D, AB, AC, AD, BC, BD, CD
These are the terms selected in the Terms subdialog box. Remember, a design that is D-optimal for one model will most likely not be D-optimal for another model.
The design points that are selected depend on the row order of the points in the candidate set. Therefore, Minitab may select a different optimal design from the same set of candidate points if they are in a different order. This can occur because there may be more than one D-optimal design for a given candidate set of points. |
