Stat > DOE > Response Surface > Analyze Response Surface Design > Graphs
Draw five different residual plots for regular, standardized, or deleted residuals.
Residuals for Plots You can specify the type of residual to display on the residual plots.
Regular: Choose to plot the regular or raw residuals.
Standardized: Choose to plot the standardized residuals.
Deleted: Choose to plot the Studentized deleted residuals.
Residual Plots
Histogram: Check to display a histogram of the residuals.
Normal plot: Check to display a normal probability plot of the residuals.
Residuals versus order: Check to plot the residuals versus the order of the data in the run order column. The row number for each data point is shown on the x-axis-for example, 1 2 3 4... n.
Residuals versus variables: Check to display residuals versus selected variables, then enter one or more columns. Minitab displays a separate graph for each column.
