1 In the Analyze Response Surface Design dialog box, click Terms.
2 Do one of the following:
linear + interactions, or full quadratic
- to
move one or more factors, highlight the desired terms then click or
- to
move all of the terms, click or
You can also move a term by double-clicking it. Click OK.
3 If you would like Minitab to use the terms that you specified in Terms as candidates and choose a good model based on them, click Auto Fit.
4 In Method, change the drop-down list from None to the stepwise regression procedure that you want.
5 If you like, use one or more of the available dialog box options, then click OK.
