Create Response Surface Design - Options
Stat > DOE > Response Surface > Create Response Surface Design > Options
Allows you to randomize the design, and store the design (and design object) in the worksheet.
Randomize runs: Check to randomize the run order of the design.
Base for random data generator: Enter a base for the random data generator. By entering a base for the random data generator, you can control the randomization so that you obtain the same pattern every time.
Note
If you use the same base on different computer platforms or with different versions of Minitab, you may not get the same random number sequence.
Store design in worksheet: Check to store the design in the worksheet. When you open this dialog box, the "Store design in worksheet" option is checked. If you want to analyze a design, you must store it in the worksheet.
