Stat > DOE > Response Surface > Create Response Surface Design > Results
You can control the output displayed in the Session window.
Printed Results
None: Choose to suppress display of results. Minitab stores all requested items.
Summary table: Choose to display a summary of the design. The summary includes the number of factors, runs, blocks, replicates, cube points, axial points, center points in cube and axial, and the value of a.
Summary and design table: Choose to display a summary of the design and a table with the factors and their settings at each run.
