Suppose you want to conduct an experiment to maximize crystal growth. You have determined that three variables - time the crystals are exposed to a catalyst, temperature in the exposure chamber, and percentage of the catalyst in the air inside the chamber - explain much of the variability in the rate of crystal growth.
You generate the default central composite design for three factors and two blocks (to represent the two days you conduct the experiment). You assign the factor levels and randomize the design.
1 Choose Stat > DOE > Response Surface > Create Response Surface Design.
2 Under Type of Design, choose Central composite.
3 From Number of factors, choose 3.
4 Click Designs. To create the design with 2 blocks, highlight the second row in the Design box at the top. Click OK.
5 Click Factors. Complete the Name, Low, and High columns of the table as shown below:
Factors |
Names |
Low |
High |
A |
Time |
6 |
9 |
B |
Temperature |
40 |
60 |
C |
Catalyst |
3.5 |
7.5 |
6 Click OK.
7 Click Results. Choose Summary table and design table. Click OK in each dialog box.
Session window output
Central Composite Design
Factors: 3 Replicates: 1 Base runs: 20 Total runs: 20 Base blocks: 2 Total blocks: 2
Two-level factorial: Full factorial
Cube points: 8 Center points in cube: 4 Axial points: 6 Center points in axial: 2
α: 1.633
Design Table (randomized)
Run Blk A B C 1 1 1.000 1.000 1.000 2 1 -1.000 1.000 1.000 3 1 1.000 -1.000 -1.000 4 1 0.000 0.000 0.000 5 1 0.000 0.000 0.000 6 1 -1.000 1.000 -1.000 7 1 1.000 1.000 -1.000 8 1 0.000 0.000 0.000 9 1 0.000 0.000 0.000 10 1 -1.000 -1.000 -1.000 11 1 1.000 -1.000 1.000 12 1 -1.000 -1.000 1.000 13 2 1.633 0.000 0.000 14 2 0.000 0.000 0.000 15 2 -1.633 0.000 0.000 16 2 0.000 1.633 0.000 17 2 0.000 -1.633 0.000 18 2 0.000 0.000 1.633 19 2 0.000 0.000 0.000 20 2 0.000 0.000 -1.633 |
You have created a central composite design with three factors that will be run in two blocks. This design is both rotatable and orthogonally blocked - see Central composite designs.
Because you chose to display the summary and design tables, Minitab
shows the experimental conditions or settings for each of the factors
for the design points. When you perform the experiment, use the order
that is shown to determine the conditions for each run. For example, in
the first run of your experiment, you would set the time (A) at 9 minutes
(1 = high), the temperature (B) at 60
Minitab randomizes the design by default, so if you try to replicate this example, your run order may not match the order shown.
