To change the default number of center points
main topic see
also
1 In the Create Response Surface
Design dialog box, click Designs.
2 Do one of the following, then
click OK.
· For
a central composite design, under Number of center points choose Custom and enter a number in Cube block. When you have more than one
block in your design, you also need to enter a number to indicate the
number of center points in Axial block.
· For
a Box-Behnken design, under Number of center points choose Custom and enter a number in the box.
When a Box-Behnken design is blocked, the center points
are divided equally (as much as possible) among the blocks. |
