1 Choose Stat > DOE > Response Surface > Define Custom Response Surface Design.
2 In Continuous Factors, enter the columns that contain the continuous factors in the design.
3 In Categorical Factors, enter the columns that contain the categorical factors in the design.
4 Do one of the following:
1 If your design is blocked, under Blocks, choose Specify by column and enter the column containing the blocks.
2 If you have a column that contains the run order of the experiment, under Run Order Column, choose Specify by column and enter the column containing the run order.
3 If you have a column that contains the standard order of the experiment, under Standard Order Column, choose Specify by column and enter the column containing the standard order.
4 Click OK in each dialog box.
