Stat > DOE > Display Design
After you create the design, you can use Display Design to change the way the design points are stored in the worksheet. You can change the design points in two ways:
How to display the points in the worksheet
Order for all points in the worksheet: Minitab sorts the worksheet columns according to the display method (random order or standard order) you select. By default, Minitab sorts a column if the number of rows is less than or equal to the number of rows in the design. Specify any columns that you do not want to reorder in the Columns Not to Reorder dialog box. Columns that have more rows than the design cannot be reordered.
Run order for design: Choose to display points in run order.
Standard order for design: Choose to display points in standard order.
Units for factors
Coded units: Choose to display the design points in coded units. Minitab sets the low level of all factors to -1, the high level to +1, and center points to 0.
Uncoded Units: Choose to display the design points in uncoded units. The levels that you assigned in the Factors subdialog box will display the worksheet.
