Stat > DOE > Modify Design > choose Modify Factors > Specify
Name the factors and assign values for factor settings.
Continuous Factors
Factor: Shows the number of factors you have chosen for your design. This column does not take any input.
Name: Enter text to change the name of the factors. By default, Minitab names the factors alphabetically.
Low: Enter a numeric value for the low setting of each factor.
High: Enter a numeric value for the high setting of each factor.
Categorical Factors
Levels: Shows the number of levels for each factor. This column does not take any input.
Level Values: Enter numeric or text values for the levels of each factor.
