Stat > DOE > Modify Design > choose Replicate design > Specify
You can add up to ten replicates of your design. When you replicate a design, you duplicate the complete set of runs from the initial design. To see the runs that would be added to a two-factor central composite design, click here.
True replication provides an estimate of the error or noise in your process and may allow for more precise estimates of effects.
Number of replicates to add: Choose a number up to ten.
