Stat > DOE > Response Surface > Response Optimizer > Options
Use to define these parts of the analysis:
Constraints: Use to hold variables at a specific value or to limit the range of possible values.
Variable: Displays all of the variables that are included in a model. This column does not take any input.
Constraint: Choose No constraints, Hold at value, or Constrain to region from the drop-down list.
Hold Value: For each variable that you choose Hold at value, enter a value to hold that variable.
Lower: For each variable that you choose Constrain to region, enter a minimum value.
Upper: For each variable that you choose Constrain to region, enter a maximum value.
Starting values: If the algorithm produces unacceptable results, you can try to improve the results by entering a starting point for the search algorithm.
Variable: Displays all of the continuous variables that are included in a fitted model. This column does not take any input.
Starting Value: Enter a value for each continuous variable. Each value must be between the minimum and maximum observed values for that variable. If you enter a constraint for a variable, the starting value must satisfy that constraint. You cannot enter a starting value for a variable that you specified a hold value.
Confidence level for all intervals: Enter the confidence level. The default is 95.
Type of confidence interval: Choose the type of confidence interval: two-sided (default), lower bound, or upper bound.
