Stat > DOE > Response Surface > Response Optimizer > Results
Control the level of detail in the display of output to the Session window.
Parameters: Check to display information about the boundaries, weight, and importance for each response variable.
Solutions: Check to display the variable settings for the optimal solution, the fitted responses, and the composite desirability.
Number of solutions to display: Enter the number of solutions to display, which starts with the optimal solution.
Prediction: Check to display the variable settings for the optimal solution and the fitted responses with their confidence and prediction intervals.
Variable ranges: Check to display the constraints that you placed on the variable.
Starting point: Check to display the starting points that you entered for the search algorithm.
