Response Optimizer - Setup
Stat > DOE > Response Surface > Response Optimizer > Setup
Specify the boundaries, weight, and importance for each response variable. You can use the default values or enter your own values. The defaults are as follows:
Goal
Lower
Target
Upper
Maximize
Minimum observation
Maximum observation
Disabled
Minimize
Disabled
Minimum observation
Maximum observation
Target
Minimum observation
Target from main dialog
Maximum observation
Response: Displays all the responses that will be included in the optimization. This column does not take any input.
Goal: Displays the goal for each response. This column does not take any input.
Lower: For each response that has a goal of Target or Maximize, enter a lower boundary.
Target: Enter a target value for each response.
Upper: For each response that has a goal of Minimize or Target, enter an upper boundary.
Weight: Enter a number from 0.1 to 10 to define the shape of the desirability function.
Importance: Enter a number from 0.1 to 10 to specify the comparative importance of the response.
