To display a surface plot for a response surface design
1    Choose Stat > DOE > Response Surface > Surface Plot.
2    In Response, choose the response variable for the z-axis.
3    Under Variables, in Y Axis, choose the variable for the y-axis.
4    Under Variables, in X Axis, choose the variable for the x-axis.
5    If you like, use any dialog box options, then click OK.
