Stat > DOE > Taguchi > Create Taguchi Design > Options
Allows you to store the design in the worksheet.
Store design in worksheet: Check to store the design in the worksheet. When you open this dialog box, the Store design in worksheet option is checked. If you want to see the properties of various designs before selecting the one design you want to store, you would uncheck this option. If you want to analyze a design, you must store it in the worksheet.
