When you add a signal factor to an existing static design, Minitab adds a new signal factor column after the factor columns and appends new rows (replicates) to the end of the existing worksheet. For example, if you add a signal factor with 2 levels to an existing L4 (2**3) array, 4 rows (1 replicate of 4 runs) are added to the worksheet; if you add a signal factor with 3 levels, 8 rows (2 replicates of 4 runs) are added to the worksheet. A replicate is the complete set of runs from the initial design.
Static design |
Dynamic design |
Dynamic design |
A B 1 1 1 2 2 1 2 2 |
A B Signal factor 1 1 1 1 2 1 2 1 1 2 2 1
1 1 2 1 2 2 2 1 2 2 2 2 |
1 1 3 1 2 3 2 1 3 2 2 3 |
When you add a signal factor to an existing static design, the run order will be different from the order that results from adding a signal factor while creating a new design. The order of the rows does not affect the Taguchi analysis. |
