The data region of a graph is where Minitab displays the data. You can place additional text, lines, symbols, and polygons in the data region. A data region uses a coordinate system in placing items relative to the points on the graph. See Region Coordinate Systems.
In most cases, graph windows have a single data region. |
When you panel a graph, you choose to display the resulting data regions on the same page. |
