Bar Chart - Data View - Data Display
overview
     how to     examples     see also
... > Data View > Data Display
Graphs that allow this function
Use to represent the data with one or more data display types, including bars, symbols, connect lines, and project lines. After creating a graph, you can:
·    Change the data display attributes (see Editing Data Display Overview).
·    Add or remove data display types (see Adding Graph Elements).
Data Display
Bars: Check to display bars that join each data value to its base.
Symbols: Check to represent each data value with a symbol.
Connect line: Check to connect the data values.
Project lines: Check to display lines that project from each data point to its base.
Categorical variables for attribute assignment: Enter up to four columns of grouping variables to assign different attributes to each group of the categorical x-scale variables. You can only use categorical variables included in the bar chart.
Calendar with week numbers
US Federal Holidays
Australia Public Holidays
