Dotplot - Data View - Data Display
overview
     how to     example     see also
... > Data View > Data Display
(Only available if a With Groups option was chosen from the dotplot gallery.)
Use to assign different data display attributes to each group based on categorical variable included in the plot. After creating a graph, you can change the dot attributes and the attribute grouping variables (see Editing Data Display Overview).
Categorical variables for attribute assignment: Enter up to four columns of grouping variables to assign different attributes to each group of the categorical x-scale variables. You can only use categorical variables included in the dotplot.
