Multiple Variables Categorical Graphs
overview
     how to      example     see also
... > Multiple Graphs > Multiple Variables
Use to control the placement and scales of multiple graphs created in the same graph dialog box. After creating a graph, you can:
·    Change the variables used to create the graphs. See Make Similar Graph.
·    Change the arrangement of the panels. See panel editing.
·    Change the scales used on each axis. See Scale Editing Overview.
Show Graph Variables Not available with all graphs.
In separate panels on the same graph: Choose to display each graph in a separate section of the same page. See Paneling Graphs.
On separate graphs: Choose to display each graph in its own graph window.
Same Scales for Graphs Available options depend on the graph.
Same Y: Check to set the same y-scale for different variables.
Same number of data values per dot: Check to use the same dot value for all graphs.
Same X, including same bins: Check to set the same y-scale and bins for different variables.
<By Variables>
