You can save a Minitab graph as a separate file outside of a Minitab project in one of several graphic file formats. The format you choose depends on application, graphic quality, and file size requirements. You may have to experiment to find the format that best suits your needs.
Most of these graphics formats can be saved in black-and-white, color, or high color. The more colors you use, the larger the file size, so save in color only if your graph uses colors; save in high color only if your graph uses a large number of colors (as in a 3D surface graph).
"Black-and-white" means there are only two colors, full black and full white, with no grays. Light colors such as yellow may translate to white. If your graph uses any colors besides black and white, save with color; because on a non-color printer the colored lines will print as shades of gray. |
