Graphs are part of your project. When you save a project, you are also saving any open Graph windows. Those Graph windows will reappear when you reopen the project.
You can open graphs that have been saved in a Minitab Graphics Format (MGF) file. You can also open graphs that are inside other project files. See File > Open Graph for more information.
You can close a graph at any time. When you close a graph, it is removed from the project. Unless you have saved the graph into a separate file, the graph will be gone forever. For information on saving graphs, see File > Save Graph As. You also can close all open graphs at once. See Window > Close All Graphs.
