Add Calculated Line
overview
     how to     see also
Editor > Add > Calculated Line
After you create a graph, you can add a calculated line that is produced by the connection of calculated y- and x-coordinates. Do this to see how the experimental points match with a theory based on a function or some other formula.
Coordinates
Y column: Enter the column containing the calculated y-coordinates of theoretical values.
X column: Enter the column containing the calculated x-coordinates of theoretical values.
Calendar with week numbers
US Federal Holidays
Australia Public Holidays
