Editor > Add > Data Display
Use to add or remove data display types from the active graph.
Data Display
Surface: Check to display a continuous surface of z-values (surface plot) or a grid of z-values (wireframe plot) that is fit to your data.
Symbols: Check to represent each data point with a symbol.
Project lines: Check to display lines that project from each data point to its base.
